Amplifier Research TWT Series Internal Coupler
The Amplifier Research TWT Series Internal Coupler device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research TWT Series Internal Coupler:
The frequency range of the Amplifier Research TWT Series Internal Coupler as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Amplifier Research TWT Series Internal Coupler.
Be careful changing these settings as RadiMation® is no longer able to verify if the Amplifier Research TWT Series Internal Coupler is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
