AnaPico APULN 12.75G
The AnaPico APULN 12.75G device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the AnaPico APULN 12.75G:
The frequency range of the AnaPico APULN 12.75G as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the AnaPico APULN 12.75G.
Be careful changing these setting as RadiMation® is no longer able to verify if the AnaPico APULN 12.75G is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: AnaPico APULN 12.75G
- Google image search: AnaPico APULN 12.75G
