AnaPico APULN 20G
The AnaPico APULN 20G device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the AnaPico APULN 20G:
The frequency range of the AnaPico APULN 20G as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the AnaPico APULN 20G.
Be careful changing these settings as RadiMation® is no longer able to verify if the AnaPico APULN 20G is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
