Anritsu 68369A
The Anritsu 68369A device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Anritsu 68369A:
The frequency range of the Anritsu 68369A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Anritsu 68369A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Anritsu 68369A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
