Antenna Research AN 8200J1
The Antenna Research AN 8200J1 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Antenna Research AN 8200J1:
The frequency range of the Antenna Research AN 8200J1 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Antenna Research AN 8200J1.
Be careful changing these settings as RadiMation® is no longer able to verify if the Antenna Research AN 8200J1 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Antenna Research AN 8200J1
- Google image search: Antenna Research AN 8200J1
