Application.AutoSave.AtStart
This advanced option specifies if the test data should be automatically saved when the test is started. This will cause that the test is directly assigned a new test number, and that it is already visible in the EUT window while the test test is still running. The default value of this advanced option is True.
There are other advanced options available that are related to this advanced option:
- Application.AutoSave.AtStart
- Application.AutoSave.DuringFirstTest
- Application.AutoSave.Interval
- Application.AutoSave.ReopenedData
- Application.AutoSave.AskSureToCloseTest
| Warning: | Any change and/or modification to the advanced options, can result in unexpected results and/or incorrect measurement results. Changes in any advanced option should be verified and checked very carefully! |
