Applied Systems Engineering Model 200K (Manual controlled)
The Applied Systems Engineering Model 200K (Manual controlled) device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Applied Systems Engineering Model 200K (Manual controlled):
The frequency range of the Applied Systems Engineering Model 200K (Manual controlled) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Applied Systems Engineering Model 200K (Manual controlled).
Be careful changing these settings as RadiMation® is no longer able to verify if the Applied Systems Engineering Model 200K (Manual controlled) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
