Bird 100-CC-FFN-30
The Bird 100-CC-FFN-30 device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Bird 100-CC-FFN-30:
The frequency range of the Bird 100-CC-FFN-30 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Bird 100-CC-FFN-30.
Be careful changing these settings as RadiMation® is no longer able to verify if the Bird 100-CC-FFN-30 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
