Bonn 0118-1M
The Bonn 0118-1M device driver is a Pre-Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Bonn 0118-1M:
The frequency range of the Bonn 0118-1M as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Bonn 0118-1M.
Be careful changing these setting as RadiMation® is no longer able to verify if the Bonn 0118-1M is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Bonn 0118-1M
- Google image search: Bonn 0118-1M
