Bonn 0118-3G
The Bonn 0118-3G device driver is a Pre-Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Bonn 0118-3G:
The frequency range of the Bonn 0118-3G as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Bonn 0118-3G.
Be careful changing these settings as RadiMation® is no longer able to verify if the Bonn 0118-3G is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
