Bonn BLMA 1060-30DS Band 1
The Bonn BLMA 1060-30DS Band 1 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Bonn BLMA 1060-30DS Band 1:
The frequency range of the Bonn BLMA 1060-30DS Band 1 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Bonn BLMA 1060-30DS Band 1.
Be careful changing these settings as RadiMation® is no longer able to verify if the Bonn BLMA 1060-30DS Band 1 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Bonn BLMA 1060-30DS Band 1
- Google image search: Bonn BLMA 1060-30DS Band 1
