Bonn BLMA 4018 Band 1
The Bonn BLMA 4018 Band 1 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Bonn BLMA 4018 Band 1:
The frequency range of the Bonn BLMA 4018 Band 1 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Bonn BLMA 4018 Band 1.
Be careful changing these settings as RadiMation® is no longer able to verify if the Bonn BLMA 4018 Band 1 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
