Bonn BLWA 0818-10D
The Bonn BLWA 0818-10D device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Bonn BLWA 0818-10D:
The frequency range of the Bonn BLWA 0818-10D as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Bonn BLWA 0818-10D.
Be careful changing these settings as RadiMation® is no longer able to verify if the Bonn BLWA 0818-10D is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
