Bonn BLWA 0825-160 Band 3 (1000 - 2500 MHz)
The Bonn BLWA 0825-160 Band 3 (1000 - 2500 MHz) device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Bonn BLWA 0825-160 Band 3 (1000 - 2500 MHz):
The frequency range of the Bonn BLWA 0825-160 Band 3 (1000 - 2500 MHz) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Bonn BLWA 0825-160 Band 3 (1000 - 2500 MHz).
Be careful changing these settings as RadiMation® is no longer able to verify if the Bonn BLWA 0825-160 Band 3 (1000 - 2500 MHz) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Bonn BLWA 0825-160 Band 3 (1000 - 2500 MHz)
- Google image search: Bonn BLWA 0825-160 Band 3 (1000 - 2500 MHz)
