Bonn BLWA Series
The Bonn BLWA Series device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Bonn BLWA Series:
The frequency range of the Bonn BLWA Series as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Bonn BLWA Series.
Be careful changing these setting as RadiMation® is no longer able to verify if the Bonn BLWA Series is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Bonn BLWA Series
- Google image search: Bonn BLWA Series
