Bonn BSA 0025-150
The Bonn BSA 0025-150 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Bonn BSA 0025-150:
The frequency range of the Bonn BSA 0025-150 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Bonn BSA 0025-150.
Be careful changing these setting as RadiMation® is no longer able to verify if the Bonn BSA 0025-150 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Bonn BSA 0025-150
- Google image search: Bonn BSA 0025-150
