Bonn BSA 0150-150D
The Bonn BSA 0150-150D device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Bonn BSA 0150-150D:
The frequency range of the Bonn BSA 0150-150D as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Bonn BSA 0150-150D.
Be careful changing these setting as RadiMation® is no longer able to verify if the Bonn BSA 0150-150D is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Bonn BSA 0150-150D
- Google image search: Bonn BSA 0150-150D
