Bonn TWAL 0102-200 (VDS)
The Bonn TWAL 0102-200 (VDS) device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Bonn TWAL 0102-200 (VDS):
The frequency range of the Bonn TWAL 0102-200 (VDS) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Bonn TWAL 0102-200 (VDS).
Be careful changing these settings as RadiMation® is no longer able to verify if the Bonn TWAL 0102-200 (VDS) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Bonn TWAL 0102-200 (VDS)
- Google image search: Bonn TWAL 0102-200 (VDS)
