CISAM 100 - 500 MHz
The CISAM 100 - 500 MHz device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the CISAM 100 - 500 MHz:
The frequency range of the CISAM 100 - 500 MHz as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the CISAM 100 - 500 MHz.
Be careful changing these settings as RadiMation® is no longer able to verify if the CISAM 100 - 500 MHz is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
