CMT LAH 0750
The CMT LAH 0750 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the CMT LAH 0750:
The frequency range of the CMT LAH 0750 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the CMT LAH 0750.
Be careful changing these settings as RadiMation® is no longer able to verify if the CMT LAH 0750 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: CMT LAH 0750
- Google image search: CMT LAH 0750
