COM-POWER AL-100
The COM-POWER AL-100 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the COM-POWER AL-100:
The frequency range of the COM-POWER AL-100 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the COM-POWER AL-100.
Be careful changing these settings as RadiMation® is no longer able to verify if the COM-POWER AL-100 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: COM-POWER AL-100
- Google image search: COM-POWER AL-100
