COM-POWER FCLCE-1032
The COM-POWER FCLCE-1032 device driver is a Calibration Jig which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the COM-POWER FCLCE-1032:
The frequency range of the COM-POWER FCLCE-1032 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the COM-POWER FCLCE-1032.
Be careful changing these settings as RadiMation® is no longer able to verify if the COM-POWER FCLCE-1032 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
