Camera system
The Camera system device driver is a AmplifierVoltage, dips and interrupts generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Camera system:
The frequency range of the Camera system as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Camera system.
Be careful changing these settings as RadiMation® is no longer able to verify if the Camera system is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
