Ceyear technologies 1466G
The Ceyear technologies 1466G device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Ceyear technologies 1466G:
The frequency range of the Ceyear technologies 1466G as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Ceyear technologies 1466G.
Be careful changing these settings as RadiMation® is no longer able to verify if the Ceyear technologies 1466G is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Ceyear technologies 1466G
- Google image search: Ceyear technologies 1466G
