Ceyear technologies 1466N
The Ceyear technologies 1466N device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Ceyear technologies 1466N:
The frequency range of the Ceyear technologies 1466N as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Ceyear technologies 1466N.
Be careful changing these settings as RadiMation® is no longer able to verify if the Ceyear technologies 1466N is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Ceyear technologies 1466N
- Google image search: Ceyear technologies 1466N
