Change Password
The Change Password dialog allows the end-user to protect a number of configurations through a password protection.
To activate, modify or de-activate passwords, select:
Engineers
In the Engineer window, the password window can be accessed by selecting the desired engineer and click 'Edit' and then 'Change password'.
For each individual Engineer it is possible to enabled, disabled and changed (to disable or change the password, the current password is required) the password settings. Furthermore, for the following items the protection can be enabled or disabled:
| prevents unauthorised changes to test equipment configuration. |
| prevents unauthorised changes to test engineers configuration. |
| prevents unauthorised changes to Test Setup Files (TSF) files. |
| prevents unauthorised changes to limit line files. |
| prevents unauthorised changes to correction files. |
| prevents unauthorised changes to General configuration. |
