Chapter 11
Sequence Testing[edit]
Goal[edit]
The goal of sequence testing is to run different (types of) tests after each other, without the intervention of a test engineer. These tests can be of the same type or of completely different types.
The sequence testing functionality can for example be used to:
  • Run a radiated emission test, a conducted emission test and a radiated immunity test (all performed in the same anechoic chamber) after each other.
  • Another example is the situation where different amplifiers are used for different frequency bands. For this situation, multiple TSF files can be generated where each TSF file defines one of the frequency bands. All the created TSF files, can then be placed in a sequence so they can be run like one test. The same is true for antenna polarisation, where a horizontal and a vertical TSF file can be created and be put into a single sequence.
  • three (or more) different conducted emission frequency bands can be added to a sequence file, and be tested sequentially after each other.
Warning: Sequence testing allows unattended testing. However some tests can cause dangerous situations. Please be especially aware with immunity testing!
From the main menu, select:
   Menu.svg File
      Menu.svg New
         Menu.svg Sequence
   Menu.svg File
      Menu.svg Save as
EXAMPLE 1:
Select:
   Menu.svg File
      Menu.svg New
         Menu.svg Sequence
   Menu.svg Tests
      Menu.svg Radiated immunity
         Menu.svg Substitution
   Menu.svg File
      Menu.svg Save sequence as...
   Menu.svg File
      Menu.svg Open
         Menu.svg Sequence...
Note: A copy of the selected TSF file will be added to the sequence. This means that if the original TSF file is changed afterwards, the copied TSF that is present in the sequence, will still use the original test parameters.
If the changed TSF file should also be updated in the sequence, the corresponding TSF file has to be removed from the sequence, and the changed TSF file has to be added again to the sequence.
The order off the tests in the sequence can be changed by selecting the desired test and clicking the up or down arrow in order to promote or demote this specific test.
Starting a sequence[edit]
A sequence can be started by selecting from the menu:
   Menu.svg Tests
      Menu.svg Sequence
         Menu.svg Start Sequence...
While the sequence is running, the Sequence Overview window is being shown, which shows the contents of the sequence file, and indicates which test is currently running.
The sequence overview window can also be made visible by selecting from the menu:
   Menu.svg Tests
      Menu.svg Sequence
         Menu.svg Sequence overview... .
Stopping (a test in) a sequence[edit]
To end the currently running test in the sequence, press the Stop button in the test itself. RadiMation® will then interrupt the current test as soon as possible, save the already determined test data, and continue to the next test that was configured in the sequence.
There are two ways to stop the complete sequence:
  1. Press the Stop sequence button in the Sequence overview window.
  2. Select the menu entry
   Menu.svg Tests
      Menu.svg Sequence
         Menu.svg Stop Sequence... .
When the Auto close checkbox is unchecked, the sequence overview window will not automatically close at the end of the sequence. This allows to review the actual status of the sequence, and if it has actually finished running all tests. The sequence overview window has to be closed manually by the user.
When the Auto close checkbox is checked, the sequence overview window will be closed automatically if the sequence has finished executing all tests.
Pause test[edit]
   Menu.svg Tests
      Menu.svg Tools
         Menu.svg Pause
ScreenElementDescription.svg Note Is the note (or informational message) that should be shown during the pause period, when the pause test is started.
ScreenElementDescription.svg Automatically disappear after If the checkbox is activated, it is possible to specify a timeout (in seconds) after which the pause test should automatically close. This option allows to show a message for only a determined amount of time, between two tests. When the specified time has passed, the sequence will automatically continue with the next test in the sequence.
ScreenElementDescription.svg Ok Saves the current configuration of the pause test to the TSF file and closes the window.
ScreenElementDescription.svg Cancel Closes the window, without storing the modifications to the TSF file.
From RadiMation® version 2023.1.2, it is possible to automatically start a sequence from the command line. This can be accomplished by calling "radicli.exe", which is available in the same directory in which RadiMation® is also installed.
Note: When a sequence is started with the command line interface and there is an active instance of RadiMation, the sequence will be started in the active instance. Otherwise RadiMation® will be automatically started with the same version as the radicli.exe used.
To start a sequence from the command line, first open command prompt and go to the correct path. Then pass at least the verb "startsequence", eut filename and the sequence filename.
Example to start the sequence:
cd "C:\Program Files (x86)\Raditeq\RadiMation\Version x.y.z\"
radicli.exe startsequence --eut "C:\EUT_Files\eutfile.eut" --sequence "C:\sequence files\sequencefile.seq"
The possible arguments are:
Argument Description
startsequence Required verb that specifies that a sequence should be started from the command line interface.
--eut <eutfilename> Required argument that specifies the EUT filename that should be used.
--sequence <sequencefilename> Required argument that specifies the sequence filename to use.
It is also possible to close the RadiMation® instance by calling "radicli.exe"
close Required verb that specifies that RadiMation® should be closed from the command line interface.
Example to close RadiMation®:
radicli.exe close
