Chapter 8
Conducted Emission[edit]
| Warning: | Extreme care should be taken when the LISN measuring output is switched from one phase to the other. The measurement output of the LISN is capacitive coupled to the mains line and therefore switching between Phase and Neutral will cause a voltage transient of 310 V at the input of the receiver. When no extra protection is used, this transient can easily destroy the mixer diode(s) of the measuring device.
We recommend to use a transient limiter or to disconnect the receiving device when the LISN is switched on or off. The used LISN, spectrum analyser and/or measurement receiver can be selected under the configuration, tests site pull down menu. |
LISN measurements[edit]
Frequency window[edit]
| Sets start frequency |
| Sets stop frequency |
LISN line window[edit]
When two or more LINES are selected in the same test, all data will be displayed in one graph thus losing information. However the peak list table will show on which LINE a peak was measured.
Receiver settings[edit]
| Sets the pre-amp gain. |
Max. hold measurements[edit]
In this window the number of peak hold sweeps for each measurement can be selected. If this value is set to, for example 10, the software will measure the frequency band 10 times for each turntable and antenna tower position. This value will normally be set to 1 for measurement receivers while a higher value is used for spectrum analysers. The amount of required peak sweeps is depending on the type of signal and the setting of the sweepspeed. For spectrum analysers and CW signals you can use a relatively low amount of peaksweeps, for example 10. But when you have discontinuous signals like a spark bridge, you may need 100 peaksweeps or more. A good indication if you are using enough peak sweeps is to look at the envelope of the frequency spectrum. When it has gaps or jumps then you are not using enough sweeps to determine a correct signal envelope.
Traces window[edit]
Detectors window[edit]
Peak detection window[edit]
| Under max. peaks, the user can limit the number of peak signals the software will detect and re-measure. |
Test site window[edit]
Limit lines window[edit]
Test options window[edit]
In the test options window the operator can select whether all RAW data must be stored or only the measurement results are stored. It should be noted that for full traceability, all test data should be stored.
Test site information[edit]
| Spectrum analyser | devices 2 | |
| Pre amplifier | devices 2 | |
| LISN | devices 2 | |
| Cables | ||
| 2 | cable antenna -> Preamp | Cables |
| Note: | Usage of cable correction factors is not mandatory. However, using correction factors will increase measurement accuracy during emission measurements. When in doubt contact your reseller. |
Absorbing clamp measurements can be performed fully automatically when a clamp positioner is used. The test engineer can configure a complete absorbing clamp test in the Conducted Emission-Absorbing clamp configuration menu. To enter this menu, please select
Tests
Conducted emission
Absorbing clamp
| Sets start frequency. |
| Sets stop frequency. |
Clamp movement window[edit]
| Sets the maximum clamp position. |
| Sets the minimum clamp position. |
| Number of locations from Max. distance to Min. distance that should be measured. |
| The software will automatically detect on which clamp distance the maximum measurement value of each peak is present. |
| Range over which the peak search will be performed. The initially detected clamp distance of the peak will be the middle of this Area, and the total search area for this peak will be half of this area up and half of this area down. |
| The step size for each clamp movement. |
Intelligent[edit]
In this mode the software increases the distance of the clamp from the initial point with a step equal to Step size as long as the measurement value is not more than Threshold below the already known maximum measurement value. As soon as a measurement value is detected that is Threshold below the already known maximum value, the clamp movement is reversed until the initial point and from this initial point the distance of the clamp is decreased with a step equal to Step size until a measurement value is measured that is Threshold below the already known maximum measurement value. The step on which the highest measurement value is measured, will be the optimum peak search location that is found for that peak.
Complete area[edit]
Traces window[edit]
| Current sensor | devices 2 | |
| Cables | ||
| 1 | cable preamp -> analyser | Cables |
Frequency Window[edit]
The number of peak hold sweeps for each measurement can be selected. If this value is set to, for example 10, the software will measure the frequency band 10 times. This value will normally be set to 1 for measurement receivers while a higher value is used for spectrum analysers. The amount of required peak sweeps is depending on the type of signal and the setting of the sweep speed. For spectrum analysers and CW signals you can use a relatively low amount of peak sweeps, for example 10. But when you have discontinuous signals like a spark bridge, you may need 100 peak sweeps or more. A good indication if you are using enough peak sweeps is to look at the envelope of the frequency spectrum. When it has gaps or jumps then you are not using enough sweeps to determine a correct signal envelope.
Receiver Settings[edit]
| Sets the pre-amp gain |
When a parameter is set to auto, RadiMation® will determine the most optimal settings for this parameter. If the parameter is set to coupled, the parameter will be set to automatic internally in the receiver. However, using the 'Auto' setting for the attenuator can let the analyser decides to use a different attenuator setting during (re-)measuring of a peak, which as a result can lead to measuring a higher Quasi-Peak value than the Peak value. This is related to the used analyser when auto attenuator is used. If it is not desired that the analyser can decide to switch to a different attenuator setting, then this should be disabled by the test engineer in RadiMation® by using a fixed attenuator value.
| Warning: | All these settings are generic. Therefore, always verify that the configured settings are also supported by the used hardware to ensure it is correctly used and no measurement faults are introduced. Use a fixed value to disabled interference of equipment intelligence. |
Traces[edit]
Test Options[edit]
| Select to record all raw data or only the results. When choosing only the results you will only have the data from the found peaks and the data of the final measurement when this is performed |
| Selects the method used to determine if a signal is broad band or narrow band. There are three options: Generic (The standard of your analyser)/CISPR 25 (Broad/Narrow band discrimination according to the CISPR 25 standard)/MilStandard(Broad/Narrow band discrimination according to the MilStandard |
In the limit line window the operator can select one or more limit lines to be used during the test.
Starting a test[edit]
Loading a TSF file[edit]
Tests
Conducted emission
CISPR LISN
Manual mode[edit]
For product improvements, it quite often is required to operate the test setup in manual mode. This can be done either by operating the measurement receiver (or spectrum analyser) manually or by the RadiMation® software. In our opinion it is no use to take over the buttons of the receiver without adding any extra functionality. For this reason a number of handy features are included in manual mode.
Data correction[edit]
[edit]
[edit]
Traces[edit]
In the “traces” menu, a maximum of four traces can be switched on. Each trace can be appointed to be a Max hold trace, Average trace, Write trace or be switched either to View mode or just left Blank.
Detectors[edit]
- Peak detector
- Average detector
- Quasi peak detector
- RMS detector
LISN line selection[edit]
Zoom function[edit]
When the operator wants to “zoom in” on a certain signal just use the mouse to drag a box around the signal of interest. The RadiMation® software will fully automatically zoom in to this signal. The screen, as well as the measurement receiver will be zoomed. This reduces the number of actions for the operator significantly.
Limit lines[edit]
Short cut keys[edit]
| Key | Function |
| F3 | Turn engine of the clampmover left, full speed. |
| F4 | Turn engine of the clampmover left, quarter speed. |
| F5 | Turn engine of the clampmover right, quarter speed. |
| F6 | Turn engine of the clampmover right, full speed. |
| F7 | Frequency offset down. |
| F8 | Frequency offset up. |
| F9 | Center frequency down. |
| F10 | Center frequency up. |
[edit]
Merge function[edit]
X+k*S calculation[edit]
