Chase CBL 6111
The Chase CBL 6111 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Chase CBL 6111:
The frequency range of the Chase CBL 6111 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Chase CBL 6111.
Be careful changing these settings as RadiMation® is no longer able to verify if the Chase CBL 6111 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Chase CBL 6111
- Google image search: Chase CBL 6111
