Chase CBL 6111D
The Chase CBL 6111D device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Chase CBL 6111D:
The frequency range of the Chase CBL 6111D as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Chase CBL 6111D.
Be careful changing these settings as RadiMation® is no longer able to verify if the Chase CBL 6111D is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Chase CBL 6111D
- Google image search: Chase CBL 6111D
