Chase CBL 6112A
The Chase CBL 6112A device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Chase CBL 6112A:
The frequency range of the Chase CBL 6112A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Chase CBL 6112A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Chase CBL 6112A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Chase CBL 6112A
- Google image search: Chase CBL 6112A
