Chase CLN 2060
The Chase CLN 2060 device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Chase CLN 2060:
The frequency range of the Chase CLN 2060 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Chase CLN 2060.
Be careful changing these settings as RadiMation® is no longer able to verify if the Chase CLN 2060 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
