Chase UPA 6108
The Chase UPA 6108 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Chase UPA 6108:
The frequency range of the Chase UPA 6108 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Chase UPA 6108.
Be careful changing these settings as RadiMation® is no longer able to verify if the Chase UPA 6108 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Chase UPA 6108
- Google image search: Chase UPA 6108
