Chase VBA 6106A
The Chase VBA 6106A device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Chase VBA 6106A:
The frequency range of the Chase VBA 6106A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Chase VBA 6106A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Chase VBA 6106A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Chase VBA 6106A
- Google image search: Chase VBA 6106A
