Clamp amplifier (PBC)
The Clamp amplifier (PBC) device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Clamp amplifier (PBC):
The frequency range of the Clamp amplifier (PBC) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Clamp amplifier (PBC).
Be careful changing these setting as RadiMation® is no longer able to verify if the Clamp amplifier (PBC) is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Clamp amplifier (PBC)
- Google image search: Clamp amplifier (PBC)
