Compliance Engineering CESGH-284-20-C-NF
The Compliance Engineering CESGH-284-20-C-NF device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Compliance Engineering CESGH-284-20-C-NF:
The frequency range of the Compliance Engineering CESGH-284-20-C-NF as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Compliance Engineering CESGH-284-20-C-NF.
Be careful changing these settings as RadiMation® is no longer able to verify if the Compliance Engineering CESGH-284-20-C-NF is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Compliance Engineering CESGH-284-20-C-NF
- Google image search: Compliance Engineering CESGH-284-20-C-NF
