Compliance Engineering WR284
The Compliance Engineering WR284 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Compliance Engineering WR284:
The frequency range of the Compliance Engineering WR284 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Compliance Engineering WR284.
Be careful changing these settings as RadiMation® is no longer able to verify if the Compliance Engineering WR284 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Compliance Engineering WR284
- Google image search: Compliance Engineering WR284
