Comtest LISN
The Comtest LISN device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Comtest LISN:
The frequency range of the Comtest LISN as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Comtest LISN.
Be careful changing these settings as RadiMation® is no longer able to verify if the Comtest LISN is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Comtest LISN
- Google image search: Comtest LISN
