Configurable Absorbing Clamp
The Configurable Absorbing Clamp device driver is a Absorbing Clamp which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Configurable Absorbing Clamp:
The frequency range of the Configurable Absorbing Clamp as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Configurable Absorbing Clamp.
Be careful changing these settings as RadiMation® is no longer able to verify if the Configurable Absorbing Clamp is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
The Configurable Absorbing Clamp device driver can be used to create a device driver for an absorbing clamp, even if no device driver is available for that Absorbing Clamp in RadiMation®.
