Main
Use Remote Control and send specified commands
If the checkbox is ticked, the remote control of the amplifier will be used by using the specified commands. If the checkbox is not ticked, no commands will be transmitted to the amplifier at all
Reset
The code that needs to be send to the device to initialize it in a defined state. When left blank, no command will be send.
Init
The Init code that needs to be send to device. When left blank, no command will be send.
Get ID
The code that needs to be send to device to get the identification back. A common used SCPI command is *IDN?. When left blank, no command will be send.
Returned ID
The code that is send back as a return on the Get ID code. When left blank, no check will be performed.
Deinit
The Deinit code that needs to be send to device. When left blank, no command will be send.
Wait for Operation Completion after sending command(s)
If the checkbox is checked, every transmitted command will include a check to determine if the execution of the command is finished.
Operation
Power On
The power on code that needs to be send to device. When left blank, no command will be send.
Band Selection
The band select code that needs to be send to device. When left blank, no command will be send.
Operate
The operate code that needs to be send to device. When left blank, no command will be send.
Standby
The standby code that needs to be send to device. When left blank, no command will be send.
Power Off
The power off code that needs to be send to device. When left blank, no command will be send.
Delay after power on
The time that must be waited after sending the power on command.
Delay after power off
The time that must be waited after sending the power off command.
Example
Description
Command
Parameters
Standby / Operate
OUT1
0 = RF STANDBY 1 = RF ON
Band Selection
OUT3
0 = BAND 1 1 = BAND 2
Power off / on
OUT4
0 = LINE STANDBY 1 = LINE ON
