Configurable Antenna
The following tabs are available in the advanced configuration of the Configurable Antenna:
The frequency range of the Configurable Antenna as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Configurable Antenna.
Be careful changing these settings as RadiMation® is no longer able to verify if the Configurable Antenna is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
