Configurable Attenuator
The Configurable Attenuator device driver is a Cable which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Configurable Attenuator:
The frequency range of the Configurable Attenuator as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Configurable Attenuator.
Be careful changing these settings as RadiMation® is no longer able to verify if the Configurable Attenuator is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
