Configurable Pre Amplifier
The Configurable Pre Amplifier device driver is a Pre-Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Configurable Pre Amplifier:
The frequency range of the Configurable Pre Amplifier as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Configurable Pre Amplifier.
Be careful changing these settings as RadiMation® is no longer able to verify if the Configurable Pre Amplifier is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Configurable Pre Amplifier
- Google image search: Configurable Pre Amplifier
