Configurable Resistor
The Configurable Resistor device driver is a Resistor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Configurable Resistor:
The frequency range of the Configurable Resistor as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Configurable Resistor.
Be careful changing these settings as RadiMation® is no longer able to verify if the Configurable Resistor is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
