Configurable Signal Generator
The Configurable Signal Generator device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Configurable Signal Generator:
The frequency range of the Configurable Signal Generator as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Configurable Signal Generator.
Be careful changing these settings as RadiMation® is no longer able to verify if the Configurable Signal Generator is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
ScreenElementDescription.svg Start The start frequency of the operational band of the signal generator in MHz.
ScreenElementDescription.svg Stop The stop frequency of the operational band of the signal generator in MHz.
ScreenElementDescription.svg Reset The reset code that needs to be send to device. When left blank no command will be send.
ScreenElementDescription.svg Init The Init code that needs to be send to device. When left blank no command will be send.
ScreenElementDescription.svg Get Id The code that needs to be send to device to get the identification back. A common used SCPI command is *IDN?. When left blank no command will be send.
ScreenElementDescription.svg Returned ID The code that is send back as a return on the Get ID code. When left blank, no check will be performed.
ScreenElementDescription.svg Set Frequency The set frequency code that needs to be send to device. When left blank no command will be send.
ScreenElementDescription.svg Set Carrier The set carrier code that needs to be send to device. When left blank no command will be send.
ScreenElementDescription.svg Carrier On The carrier on code that needs to be send to device. When left blank no command will be send.
ScreenElementDescription.svg Carrier Off The carrier off code that needs to be send to device. When left blank no command will be send.
ScreenElementDescription.svg Communication Opens the dialog in which the communication method to connect to the amplifier can be selected and configured.
AM
ScreenElementDescription.svg AM On The AM on code that needs to be send to device. When left blank no command will be send.
ScreenElementDescription.svg AM Off The AM off code that needs to be send to device. When left blank no command will be send.
ScreenElementDescription.svg Sine Wave The modulator sine wave code that needs to be send to device. When left blank no command will be send.
ScreenElementDescription.svg Square Wave The modulator square wave code that needs to be send to device. When left blank no command will be send.
External AM
Configurable Signal Generator Configuration Window Amplitude Modulation External.png
ScreenElementDescription.svg External On The external AM on code that needs to be send to device. When left blank no command will be send.
ScreenElementDescription.svg External Off The external AM off code that needs to be send to device. When left blank no command will be send.
FM
ScreenElementDescription.svg FM On The FM on code that needs to be send to device. When left blank no command will be send.
ScreenElementDescription.svg FM Off The FM off code that needs to be send to device. When left blank no command will be send.
External FM
Configurable Signal Generator Configuration Window Frequency Modulation External.png
ScreenElementDescription.svg External On The external FM on code that needs to be send to device. When left blank no command will be send.
ScreenElementDescription.svg External Off The external FM off code that needs to be send to device. When left blank no command will be send.
PM
ScreenElementDescription.svg Pulse On The pulse on code that needs to be send to device. When left blank no command will be send.
ScreenElementDescription.svg Pulse Off The pulse off code that needs to be send to device. When left blank no command will be send.
External PM
Configurable Signal Generator Configuration Window Pulse Modulation External.png
ScreenElementDescription.svg External On The external PM on code that needs to be send to device. When left blank no command will be send.
ScreenElementDescription.svg External Off The external PM off code that needs to be send to device. When left blank no command will be send.
