Custom equipment list in report
Question[edit]
Can I get a custom equipment list in report using the report generator?
Answer[edit]
Yes, it is possible to get a custom list of used equipment in your report. You can specify what kind of information you want to have included in the report. It is possible to include this information by including device specific report generator codes in the report generator templates. See the examples below:
Example 1:
From the signal generator we want to know the Brand and the type. The test performed is a Conducted immunity Test.
- Open the manual, chapter Report generator and Equipment for conducted immunity tests
- The report generator code needed are:
- SIGNAL GENERATOR BRAND
- SIGNAL GENERATOR TYPE
so the total text in the report generator template can be:
Signal generator: ||RI 80-1000 MHZ|SIGNAL GENERATOR BRAND||, ||RI 80-1000 MHZ|SIGNAL GENERATOR TYPE||
or:
Signal generator Brand: ||RI 80-1000 MHZ|SIGNAL GENERATOR BRAND|| Type: ||RI 80-1000 MHZ|SIGNAL GENERATOR TYPE||
Example 2:
From the spectrum analyser we want to include the hardware version and when the calibration is expired into the report. The test performed is a Radiated emission test.
- Open the manual, chapter Report generator and Equipment for Radiated Emission Tests
- The report generator code that are needed are:
- SPECTRUM ANALYSER HARDWARE VERSION
- SPECTRUM ANALYSER CALIBRATION EXPIRES
| Note: | The information of the hardware version and calibration expire date, can only be inserted correctly when this information is specified in the device driver configuration window of RadiMation. |
