D.A.R.E!! Instruments RGN6000A
The D.A.R.E!! Instruments RGN6000A device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the D.A.R.E!! Instruments RGN6000A:
The frequency range of the D.A.R.E!! Instruments RGN6000A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the D.A.R.E!! Instruments RGN6000A.
Be careful changing these settings as RadiMation® is no longer able to verify if the D.A.R.E!! Instruments RGN6000A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: D.A.R.E!! Instruments RGN6000A
- Google image search: D.A.R.E!! Instruments RGN6000A
