DARE!! Instruments RGN2006A
The DARE!! Instruments RGN2006A device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the DARE!! Instruments RGN2006A:
The frequency range of the DARE!! Instruments RGN2006A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the DARE!! Instruments RGN2006A.
Be careful changing these settings as RadiMation® is no longer able to verify if the DARE!! Instruments RGN2006A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: DARE!! Instruments RGN2006A
- Google image search: DARE!! Instruments RGN2006A
