DARE!! Instruments RPA Configurable
The DARE!! Instruments RPA Configurable device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the DARE!! Instruments RPA Configurable:
The frequency range of the DARE!! Instruments RPA Configurable as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the DARE!! Instruments RPA Configurable.
Be careful changing these settings as RadiMation® is no longer able to verify if the DARE!! Instruments RPA Configurable is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
