The DARE!! Instruments RSS2010I device driver is a Field Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the DARE!! Instruments RSS2010I:
Pre Wait Time
Wait time before starting the measurement-loop. Can be used to wait for a signal generator, and or amplifier to stabilize.
Measure
The minimum amount of measurements in the measure loop. Continues to loop even if field strength level is stable.
Wait Time
The wait time between each measurement is taken, during the measurement-loop.
Max. Difference
If the measured field strength between each measurement in the measurement-loop, is less than this value. The measured field strength is stable. The measurement-loop will then stop.
Max. Measure
The maximum amount of measure times, for the measurement-loop
Both for the leveling, and the monitoring these settings can be set individually.
The leveling is used, whenever RadiMation® is measuring the field strength, to regulate the signal generator.
If the field sensor is only used as input, without regulating on it, then the monitoring settings are used.
The frequency range of the DARE!! Instruments RSS2010I as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the DARE!! Instruments RSS2010I.
Use default start frequency
Custom start frequency
Use default stop frequency
Custom stop frequency
Be careful changing these settings as RadiMation® is no longer able to verify if the DARE!! Instruments RSS2010I is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
Communication Streams
There are several methods in which the DARE!! Instruments RSS2010I can be connected to the PC. The DARE!! Instruments RSS2010I can for example be connected directly to the PC, or through a plugincard in a RadiCentre 1 or a multi-slot RadiCentre. More information on how to use the RadiCentre is present in the product manual of the RadiCentre. The settings on the RadiCentre tab can be used to specify how the DARE!! Instruments RSS2010I is connected.
When the DARE!! Instruments RSS2010I is connected to a multi-slot RadiCentre, also the slot number in which the plugincard is fitted, should be specified.
Directly to PC
Specifies that the DARE!! Instruments RSS2010I is connected directly to the PC, without the use of a RadiCentre.
RadiCentre 1
Specifies that the DARE!! Instruments RSS2010I is connected to a plugincard that is fitted in a RadiCentre 1.
RadiCentre multi-slot
Specifies that the DARE!! Instruments RSS2010I is connected to a plugincard that is fitted in a multi-slot RadiCentre that also can be manually controlled using the display on the front of the RadiCentre. The slot number in which the plugin card is mounted can also be selected.
RadiCentre multi-slot Ultra
Specifies that the DARE!! Instruments RSS2010I is connected to a plugincard that is fitted in a multi-slot RadiCentre Ultra. This RadiCentre Ultra has no display, and can only be used when remote controlled.
The configuration on the Communication tab should be configured depending on the outgoing connection from the PC. Thus if Directly to PC is selected, the communication settings should be configured as what is actually used between the PC and the DARE!! Instruments RSS2010I itself. If RadiCentre 1, RadiCentre multi-slot or RadiCentre multi-slot Ultra is selected, the communication settings should be configured as what is actually used between the PC and the RadiCentre. In the configuration where a RadiPower is connected with USB to a multi-slot RadiCentre, which is connected by GPIB to the PC, the communication settings of the RadiPower device driver should thus be GPIB.
If the DARE!! Instruments RSS2010I is for example connected to slot 3 of a multi-slot RadiCentre which has IP address 192.168.178.95 and is connected by LAN to the PC, the following settings should be configured in the device driver of the DARE!! Instruments RSS2010I:
- RadiCentre tab
- Communication tab
- Communication Stream: VISA
- LAN: 192.168.178.95
The Firmware update tab can be used to update the firmware of the DARE!! Instruments RSS2010I.
Firmware
Specifies the filename of the firmware update file that should be used to update the firmware of the measurement device.
Browse
Allows to select the firmware update file.
Update firmware
Starts the actual firmware update. First some checks are performed, and if those checks are successful, the actual firmware update is performed.
Status
Shows a message during the firmware update, indicating the performed action and the actual status.
Warning:
The firmware update can take a few minutes. During the actual firmware update the window is disabled, and cannot be closed. It is possible that Microsoft Windows shows messages that the RadiMation® software is not responding. Ignore those messages and do not kill, abort or end the software. Also do not disconnect the connection between the DARE!! Instruments RSS2010I and the PC, while the firmware update is being performed.
The RadiSense tab can be used to configure the specific settings of the DARE!! Instruments RSS2010I.
Direction
If the field strength of a specific single axis or an isotropic value should be measured.
Filter Setting
The filter that should be used during the measurements.
The User Correction tab can be used to upload the data of an user correction into the DARE!! Instruments RSS2010I. This correction data can be used by the probe internally to to correct the measured values.
Use user correction if available
If this option is activated, and if a user correction is stored in the probe, then the correction will be used by the probe itself, to internally correct the measured value with the user calibration data. If this option is off, no correction of the measured values will be done.
Browse
Allows to select the correction file that contains the user correction data of the DARE!! Instruments RSS2010I.
Program correction table
Starts the actual uploading of the correction table. First some checks are performed, and if those checks are successful, the actual uploading is performed.
Download correction table
Downloads the user correction table from the probe, if available. Then displays a 'Save As' prompt to save the table as a RadiMation correction file.
